Smaller Alt. Pulley.
flareside_thunder
7,812
246
I need to know what smaller pulleys will fit on our (Gen 9) 95 amp alternators? I just need this junkyard upgade until I can do a 3G conversion, this 30 amp draw fan is killin me...and my battery. My alternator is on it's way out anyways so I'm having it rebuilt and turned up tomorrow. But, wouldn't hurt to have a bit more spinnage. Thanks guys.
Go to your local auto electric shop. My guy hooked me up with a bolt-on 130 amp alternator that has a lot of juice in the low rpm's that's popular with the snow plow guys.
F 150Cobra
"Wild HoRsE" Got Torque?
3,642
104
Aruba
yupp the model number is 7771 i think its for a tuarus is a direct bolt on 130 amp alt even for my gen8
I didn't convert anything-- I just upgraded to the 130amp. Only problem was that my particular truck uses a side-mount alternator and the taurus uses a pivot mount, so I had to swap the guts from a good pivot mount unit into a garbage side mount unit's housing to use it on my truck.
Just make sure it's the right case-- there are 3 different styles and 3 different regulator clockings:
Case styles:
Clockings:
The clocking can be adjusted after you buy the alternator by removing the case bolts and spinning it, but it's just a pain in the butt if you can avoid it by getting the right one in the first place.
