It was a sale on email....she bought me the blue electric 1500 psi yes... worked awesome!
heard they work pretty well.. just always worry bout mixing electricity and water + pressure...
yeah, but if it starts to leak internally or something..... idk... im an optimist when it comes to our stuff... but the electric PW.... eh..... idk...
Yup, one of the things on my "Bump to do" list this summer. I actually bought all the material to convert and encapsulate the frame and axles from Eastwoods.....looking forward to doing this to preserve the frame long term as it will be my winter driver.
Sounds good man. What about repaintin the engine and engine bay after you get it all cleaned up under there. Fresh Ford blue on engine and fresh semi or gloss black in the engine bay would look good.
once you get the big gunk off, try castrol super clean, it takes the rest really nice. Also spray it on rubber (tires, windshield gasket, etc), then pressure wash. You won't believe how black and clean the rubber will be. After, put Armor All tire foam on the tires, it is unbelivable!
Bought that same stuff from Eastwood.com Ken. Think I got a quart of it. Haven't had the chance to use it yet, but cannot wait to see if it is as good as Por 15
I need to look at getting that rust converter then. I have been using elbow grease and naval jelly.
I've used the Purple Power to, it's real similar to Super Clean. I personally think Super Clean works better, and it's really amazing what it does to rubber. I also takes diesel off of the fuel tanks on my company truck, leaves the tank nice shiny white.
My first pressure washer was and electric one, worked great. When it finally crapped out, I ponied up and bought a gas powered 5 horse, 2500 psi. If you like the electric one, you'll love the gas powered job. I use mine around the house all the time, wash all my trucks with it, the patio, etc... It's invaluable when I get stupid enough to go muddin in my Bronco or Hi Boy (lots of clay around here). Also pretty awsome when you pull an engine, makes cleaning the engine compartment really easy, and you can really do a good job while the engine is out (hint hint Ken, you could really shine that thing up if you pulled the engine!).
The Super Clean is the Castrol product, right? Is it similar to Simple Green? Does it come in great big ole jugs?
I have an electric pressure washer I bought about 6 years ago. The only gripe I have about it is the fact that you have to keep up with the extension cord. That dang thing gets wrapped up with the hose and wand hose really easy...
Ken, have also heard that you can use regular ole hand cleaner on the steering rubber pieces to get em looking good. Haven't tried it yet though.
