Please HELP stranded in KC.
MikeStoke
Army Firefighter
I am having a no start issue. It will crank and it sounds like a old time carurbrator that is flooded! I thought the fuel might of jelled but it has been inside 65 Deg. for 4 hours in a shop. I have it pluged in and put 2 new batteries in this morning... What do I do, Where do I start? I know the glow plugs are weak, but usually pluged in it starts fine.
polarbear
just growing older not up
12,878
607
Boring, Oregon
bumpety bump
Are you getting oil pressure when trying to start?
Im not sure if I am or not Vince. I think it is falling to 0 while cranking. I left it at the shop tonight so I wont be able to check intill 8 am. If not what does that mean? and if I Do what is the next step?
By the sounds of that, its a high pressure oil problem (pump, stc fitting, stand pipe, etc) Its quite labor intensive. Do you have your extended warranty still?
MikeStoke
Army Firefighter
Thats what i figured. Is it possible that it could of jelled up and needs to thaw? the temps have been in the teens winds steady about 20mph and 8 inches of snow.
MikeStoke
Army Firefighter
Doubt it because of the lack of oil pressure.
Vince, I tried to start the truck this morning and there WAS oil pressure... I am trying to find a shop open on sunday up here to get it on a machine so I can figure out what is going on. Does anyone know of any shops that are open on sunday in KC? If not, what can I try? Is there a relay or something that is common that I can buy and try?
Codes (even if theres no light), monitoring data (ficm signals, camshaft/crankshaft signals, etc.) fuel pressure, icp oil pressure (500 psi just to start it)
