surewhynot
Rep whores make me sick
97 F250 HD, 2wd, 5.8, 5 sp
The rod that goes from the clutch master cylinder to the clutch pedal is steel, but the eye at the end where it hooks to the pedal is plastic. Twice I've had the eye break on me. Just curious if this is a common problem or is it just my luck. The second time it happened, instead of replacing it again, I welded a section of a bolt to the steel part of the factory rod and a couple of washers to that, so it would make an all steel rod and eye. I don't think I'll ever have that problem again. It ain't pretty, but it works.
