CaFordDude
I do not honestly believe that the cab issue has anything at all to do with Ford's sales numbers. I think that is a stretch to say that.
Yes..I understand part of that for emissions. I do not understand why everything is tied into one GEM and it cannot be monitored with the OBDII code readers. The codes are supposed to tell us (the users) what area to look in. Again...ford made it so we have to take it to the dealers.
I have two code readers, neither of which will read the GEM. [/QUOTE}
Brian,
Here is a thread i started that should address all your questions on the different code readers/scanners and compatibility.
www.fordtruckfanatics.com/forum/showthread.php?t=1940
www.fordtruckfanatics.com/forum/showthread.php?t=1941
You are in the computer field so this should make perfect sense. As computers have evolved so have the computer systems in vehicles. Yes todays mechanic has to not only be a good mechanic but also proficient with computers. But hey so does a doctor or lawyer, construction worker and many other fields now require computers in the daily tasks. Computers are a double edged sword, they help streamline many things, controll precision much better, track mundane tasks and reduce the number of people required to perfrom the same job. However they do require continued training, monetary outlay for the equipment and continued updates & support.
Do i like the simplicity of older vehicles (and any mechanical item) and the ease of working on them, i most certainly do. However, i would not trade my nice comfortable late model vehicles for anything. The new vehicles have better performance, less maintenance and are more comfortable and handle better. I do not miss sticking distributor points or having to clean/change & reset points and plugs on a regular basis or rebuilding the carburator just to keep the car operating efficiently. On the newer gas vehicles, i don't even mess with spark plugs for 100K miles and points are non-existant, couldn't do that with the older cars.
In life however we are never static unless we are dead, life is always changing and evolving. We either change and adapt with it or fall by the wayside.
This thread now bores me... I'm not reading anymore. And YOU CAN'T MAKE ME!
So, it looks 50/50 on here, for it/against it. Is it because it just looks so drastic, or is it that we're not used to seeing something like that?
There will be no law suits, its the same bolts, in the same place. The same wiring harness, the same steering column. There is no basis for concern.
