Just be careful when removing the old studs if you plan on re-using them. If you pound em too hard, you'll damage the threads and won't be able to throw a lug nut back on em.
Ouch... that ain't good.
I bet you will be replacing your brakes to, huh?
No theyre easy just pull the hub and rotor off and pound or press the studs out then get your new rotor and new studs and pound em back in.
I'm gonna be replacing everything,so it's not much of a worry to me.My brakes still work.Barely.lol.
If the smoke rolling was from heat, then i would for sure pull them wheel bearings and have a look at em, if it was from brake fluid getting on to the brakes, then you would be ok. But other wise, pull them bearings asap.
Good I aint gonna type that much again.
