News and Questions
News. Today to rolled over the 100k mark, the truck is running fine.
Questions. What maintance to do. Motor and Truck.
The EGR cooler was replaced at 98K and I have a new up/delete pipe and a plug for the cooler I hope to get to soon. smiliegitrdone
Thanks for any suggestions.
Just steady as she goes! Keep up all maintenance as you have been doing. A coolant filter in my book is as important as it gets. Its the only mod I approve of.
Beachbumcook
Kansas Chapter member
I would replace your fan belt.
Flush and refill coolant if not done so before now.
Have you serviced your front and rear diff's?
Have you flushed your brake fluid?
When did you last change yoour air filter?
Knowing you, your up to date on tranny, transfer case, fuel filters and oil filters.
I am at 129,700 miles as of today!!!
Hey Beachbumcook see you adding more miles. Forgot about the tranfer case.
back to wal-mart the that lube thanks.
Thanks All for the input, going to get the servicing done next few day I hope.
Beachbumcook
Did you remember the following:
1) It's time to change your spark plugs?
2) Did you change the air in your tires?
3) Did you change your wipers?
4) Did you flush and replace the water in your batteries?
5) Seriously, how about your P/S fluid... add a P/S fluid filter like I did.
Beach; I may justed do that
Thanks to all for the infor.
John
