New Member with 1965 F250 4x4
Hi all!
I am proud to say I just acquired a 1965 F250 4x4 to restore (with a few mods). A little help with the warranty number would be nice: F26DR638851
WR:120
COLOR: W
MODEL: F260
BODY: B81
TRANS: N
AXEL: 25
Also, looking at a 1965 f100 as a donor. I think all the body parts are interchangeable, right?
As much surface rust as it has, the body looks fairly clean. Nice truck!
I don't have a 65 book handy....but a 66 book sez:
Color...med blue
F260...6800gvw
N...5spd Clark
25....Dana 60 4.56/5200lb
Thanks for the info DNFXDLI! TJ, it came from a farm in Wilbur. I just found an F100 in solid shape (2 wheel drive) sitting in a field in Idaho. I will be trying to pick it up for a few parts. I figured they would interchange.
There are a couple small rust wholes in the bottom back corners of the bed. But that is it. Everything else is surface rust. There are a couple wrinkles in the passenger side front where they clipped it with a combine header. Not to serious.
BKW
Ford Parts Guru
Hi all!
F26DR638851 / WB: 120 / COLOR: W / MODEL: F260 / BODY: B81 / TRANS: N / AXLE: 25 / MAX GVW LBS: 6800 / CERT NET HP: 172 / RPM: 4000 / DSO: Omitted.
Maybe yes, maybe no.
F26 = F250 4WD
D = 352 2V
R = San Jose CA Assembly Plant.
638851 = 1965, assembled December 1964.
120" Wheelbase.
W = Medium Blue
F250 4WD, 6,800 lbs. GVWR
B81: B = Medium Blue Crush Vinyl & Medium Blue Ladder Pattern Woven Plastic // 81 = 81B Custom Cab.
N = New Process 435 4 Speed Manual Transmission. TRANS code N used in 1965 only for the NP435. TRANS code A was used 1966/79.
25 = Spicer/Dana 60 Rear Axle / 4.56-1 / No Limited Slip / 5,200 lbs. Rear Axle Capacity.
6,800 lbs. Gross Vehicle Weight Rating.
172 net HP @ 4,000 RPM
If the 1965 F100 is 4WD, the body is the same. If it's 2WD, it is not the same!
1961/64 F100/1100 - 1965 F100/250 4WD - 1965/66 F350/1100 - 1966 F250 4WD have a cab step, visible when the doors are opened.
1965/66 F100/250 2WD & 1966 F100 4WD use the same cab, there is no cab step.
The steering column, clutch linkage isn't the same either.
The Styleside bed is also different: 1957/60 Styleside beds installed on the following 1961/66's:
1961/64 F100/250 4WD - 1961/66 F350 (9' Express) / 1962/63 F100/250 2WD - 1965 F100/250 4WD - 1966 F250 4WD
P/S was not available for F100/250 4WD's until 1973 and then it's Power Assist P/S thru 1975 for F100 4WD, 1975 F150 4WD, 1977 for F250 4WD
