I agree that the coating and clearancing will go a LONG way to helping, but I don't think that needs to be done to Billet gears. I'd still rather the gears give out first and the stock ford ones cost me $16.66. The machining will add to that, but not to the point of what Billet gears will cost.
That is a reasonable outlook, I think I''m gonna have a discussion with Matt on that issue. Maybe we'll revise the plan.
I hope Matt figures this one out for us. I think it's the way to do. Either this or I had a suggestion from another member, can't remember, might have been Fellro (forgive me if I'm wrong), that you could hook up one or even two electric oil pump via a low pressure sensor so they'd come on when pressure dropped below a set point thus protecting the engine in case of LPOP failure. I think it's a VERY viable alternative and you ought to suggest it to Matt.
LOL Actually it was my suggestion... And I'll definitely be doing that.
This was funny, Matt suggested a dry sump system to me and said it would allow the engine to run even upside down. I said, if my 8000 pound truck is upside down, I've got WAY more issues than the damned engine! ROFLMAO
Dry sumps are awesome, it was more a money/time/development issue that has led me away from the dry sump idea. They are inhibitively expensive.
From my research and thinking, the main problem with the FluidAmpr at higher RPM's is the weight. Think about the engine spinning 4200-5000 RPM's and then it shifts and drops 1400-1600 RPM's. All that extra mass has to suddenly slow down. I think that would cause a quick but sharp deflection to the end of the crank, right where those LPOP gears are.
Ahhhh... the light turns on now.... I had not though of the massive deceleration condition. I will do some more research. But you are suggesting that that the LPOP fails right after a shift not right before?
WUS!! ROFLMAO Trust me, once you try it, you WON'T stop. It's impossible!!
Yeah... That's what I'm scared of and then I'll be hooked
Water Injection cools the EGT's, NOT water temp. The fan takes the heat circulating air through the radiator. Until they develop some higher flowing electrics, I'm staying with the stock fan. Once it gets warm, it even takes the stock fan a while to get it back down.
I understand what you're saying, but what heats the coolant? If I can keep my EGTs down in the 800-900 range (which is not too for outside normal driving temps) I should be able to keep my engine temps reasonable. It will hopefully just be a matter of keeping the water injection aggressive enough to keep the temps down. It'll be an intersting experiment nonetheless.
OMG!! If I win the lottery or Publisher's Clearing House, I've already told him I'm bringing him my truck and a suitcase full of money cause we're goin to town!! I SO want to be the first 6.0L to hit the 1000HP on #2 only!! All it takes is money and my freakin' wife won't let me sell the house and live with my parents!
I would love to see that too, I don't think the 1000+HP will be streetable though.... The injectors/nozzles would be so huge it'd very hard to run any way but flat out... LOL
No problem. I only want to see the 6.0L live up to it's true potential. Even if it's not mine.
Lots of people don't think that way though
