d-kuzmen
Master Ford Tech
Double check your radius arm bushings put a prybar between the bar and the frame, shouldn't be much movement, the drive side usually wears first, check the gap between the washer and the frame make sure theres no signs of it touching the frame, also check the swaybar bushings the bolt to the frame and the ones pressed into the arms. Tell the dealer to install the chasis ears on it. I would also recomend looking at the body mounts, make sure there all there and tight. Also check the steering box bolts and steering shaft.
