- 88
- 1
gota new riddle for ya'll. gave my truck a tune up and an oil change. it was in desperate need of both. i was out the other night just cruising around and outta the blue it started missing. so i pulled the new plugs and loooked them over to see if maybe something fouled them out. checked them for spark as well using the new wires. all 6 had spark and the appearance of all 6 plugs appeared normal. considering that they're about a week old. no oil,no corrosion,etc. so i decided to take it for a "spirited" drive just to see if it would help it any. while driving i noticed that when i "romp" on it the miss goes away and the truck runs as it should. but when i drive it "normally" it runs rough and also does so at idle. i have a repair manual for my 86 bronco 2 and i looked up possible causes for misfiring and it just says to check plugs,wires,cap,and rotor. it doesnt matter if the engine is cold or warm the miss is there but when i put my foot into it it runs perfectly no miss,clatter,tapping etc. any ideas?? im stumped here. as always any and all advice is greatly appreciated. truck has the 300 6 single bbl carb. and approx. 182k miles. thanks again for the tips. bill
