78F250
New Jersey Chapter member
I found this plate on the 10 bolt rear axle. I think 3 31 is the gear ratio? What are the other numbers?
So 3.31:1 is good for daily driving or towing?
My son, who I got it from, said it tops out around 60/65 mph. Seems strange with a 400 w/4bbl.
Means it's good for daily driving. Might be a little sluggish off the line, but the rpms will be low on the highway. The higher the gear (numerically lower) the lower the Revolutions Per Mile are going to be and vice versa.
Rep points to you man! That was the most understandable, short sweet explanation of gear ratios and what it means I've ever read!
Dak
Revolutions Per Mile? That's a damn big motor!
There it is! ...the slush box allows for taller gears than a manual.Only near the top of 4% grade will the C6 shift into second gear
