My 460 build?'s
I am building a 460 here is the specs
Block D9TE-AB
Oil pump M84BHV
Venolia flat top pistons #435(.o3o" below deck) about 9 to 1
Hooker headers
ported stock heads D3VE (E8TE-DA)(2.08"in and 1.65"ex)95cc
SVO roller-rockers c351 1.73
performer intake
holley street advenger 770
recurved 12 degrees btdc base
Comp cams 252BH-10
Timing chain straight up
Fuel pump 12 839 (07054)
C6 stage two shift kit and stock TC(planning on buying a 2800stall)
rear ford 9" with 3.55 gears
My question is I am planning on going with comp cams X4270H http://www.compcams.com/Cam_Specs/CamDetails.aspx?csid=998&sb=2 The reason I am thinking of going with the 4x4 cam is to keep rpm's lower.
What do you think of my cam choice?
How huch power do you think it well make?
Thanks in advance
flareside_thunder
Florida Chapter member
7,812
246
you gonna do a 3.55 posi?I like that gear that's what;s in my truck and it'll get a little bit of wheel spin but not much which is good.....(on the street)
surewhynot
Rep whores make me sick
13,843
821
Florida
The cam looks like it will give a great low to mid range punch. Along with it, you will probably need a higher than stock stall converter for the tranny. It probably won't like to idle in gear with a stock converter.
What is going to be your primary use for the truck? You may want to consider going a step milder in your cam choice. (Wow, I can't believe I just uttered those words!) :D
flareside_thunder
7,812
246
you're gonna need to check your P-V clearance with that high of a lift cam and 1.7 rr's.....you got some good duration and and some decent lift.....but like i said check the P-V clearance.Looks like a good cam smiliewhathesaid
The truck is just my toy. Just want something fun to drive around. Iam planning on a 2600stall converter. surewhynot I here what you are saying mite be a bit on the high side for cam choice. flareside_thunder I well for sure check the P-V clearance.
Thanks guy's
surewhynot
13,843
821
Florida
If it's just a toy and you're planning on a higher stall converter anyways, I'd go for it.
