Fordzilla80
Ranger Lariat
If you don't have the owners manual, you can get a brand new original from helminc.com.
Thanks Bill. I may do that. It's on the Ford website too.
So just keep an eye on it.
Just to clear a few things up here... That truck was manufactured by Ford with intent for the consumer to generally not use the overdrive disable switch, unless they need to kill that extra gear. Translation-- leave the switch alone and let the overdrive do it's thing unless you NEED to disable that gear (ie, when towing or pulling up a long steep grade). The switch was never meant to be used as a manual toggle every time you want to enable and disable overdrive-- it's there to give you the ability to disable it when needed; otherwise keep it on and use it while driving.
In-town driving will NOT be affected by disabling that switch. The overdrive gear is not active until your tranny is ready to shift out of 3rd. In my truck, at light throttle, it'll switch into OD as early as 35mph but that's VERY light throttle and if I move the throttle at all then it'll drop back down to 3rd. Generally speaking mine won't shift into OD until at least 45mph. If you're really underrevving it then the tranny will drop back down to 3rd-- this is fine. But those speeds will vary from truck to truck depending on tranny gear ratios, rear axle gear ratio, and tire size.
Other than that-- Ernie is correct. Lower RPMs means the pump (read: torque converter) is spinning at slower speeds which means less fluid circulation. If you're in a situation that will stress the transmission then definitely turn off OD, otherwise you should forget that you even have the switch. Most consumers have no idea what overdrive is or does, and therefore Ford would be pretty naive to think that their customers would be smart enough to constantly toggle it on and off else smoke the transmission immediately.
Well, the ol girl is still doing the O/D Off light thing. She seems to do it every other week, and on the same roads each time. It almost always happens on a highway at 50MPH and up, and a few times it has done it on a hill. It's definitely something wrong with overdrive, as that's the only time it happens.
Any ideas what it could be before I have to argue with the tech at the transmission shop that it does not need a full rebuild?
I was just seeing what everyone else thinks needs to be replaced.
You need to replace it with a 5-speed and call it a day
Welcome to the site, gapcomputer.
