I had a Pinion Gear try to escape through the Differential cover. :-( Bad Pinion gear). Information I have on the truck is below. My question is... Is the "H9" Axel code on the door placard enough to positivley identify the rear end as one I could use with my truck if I pull it from an F150 or Bronco? I'd hate to pull one from a junkyard only to have it not fit or the gear ratio be wrong.
1989 F150, 4.9, M50D E9TA. Transfer case is a Borg Warner 13 56. The window sticker indicated a 3,55 Optional Ratio Axle. Limited slip. Another number I am pulling from another sheet shows the Rear Axle as an 807D There also appears to be an "Exciter Ring" for the rear antilock breaks. I doubt they work. The placard on the door indicates H9 for the Axle code. I could see no number stamped on the axle tubes. Any ratio plate attached to a differential bolt is long ago rusted away.
Any thoughts????
Thanks, Joe
Any thoughts????
Thanks, Joe
