Probably for the better... Sounds like the kind of gun you wouldn't want your prints onNope. left it there.
How so? Weld in a piece of C channel that is exactly the same as the existing frame rails, and it's just like stock. Where's the weak point?Well to make a 4door bronc, you would have to cut and add the to frame, how sturdy would that be?? wouldn't that make for a large weak spot..
Well of course if you want to talk about it at the MOLECULAR level, yeah it ain't the same. But for the purpose of binding the two pieces of metal together PERMANENTLY, welding works just fine.Uh... I'm not sure that's really true. I'm not knowledgeable enough about metallurgy to really explain it, but cutting a piece of metal and welding it back together WILL get you a piece with different properties than the single solid piece.
A good weld is just as good as a solid piece of metal with no weld at all. Keyword here is GOOD weld. What does a good weld look like? Well just have a look at the welds where Centurion added a piece of C-channel to my frame when they stretched it.
Yeah I wouldn't attempt anything like it myself, though a backyard mechanic with a good welder and the skills to use it could most likely handle the job.Wow thats a hell of a weld, looks like the welds the Rig manufacturers use, that's no normal garage welder I guess trying to make a 4 door bronco your self would be a little out of the question.
I'm talking about at a macro level.
As in, if you load it to failure, it will fail at a different loading and in a different way after welding than before.
Really that's awesome how much would it cost to make my truck a 4 doorNope other than the weld its self .you can section frame yourself and have welded up . I 've done it several times.
