I have a 74 F250 with 360 & T18 trans. I was wanting to know will a Clark 285V bolt up to a FE 360? An I bought a new clutch for it before I found the trans needed attention. Will the clutch work with the Clark 285V trans?
I think Your clutch will not work with the Clark. Also you will need to do some machine work for the input shaft to fit the pilot bearing for the FE360.
