89frankenford
Grabber Green Consultant
ok so i finally got a vid of my codes. my old mini SD card craped out and i got a new one. as most of you know ive been trying to find why my truck has a misfire and is not having the power it did when i rebuilt th motor 2 years ago. well here is the codes
here is how i think it breaks down
flutter----84---84---1---33---41---33---41
so judging by that i have a code 84, 33, and 41
84 = EGR Vacuum Solenoid circuit failure.
33 = EGR valve opening not detected.
41 = HEGO sensor circuit indicates system lean (right side).
this is all KOEO and according to www.fordfuelinjection.com code 84 is a KOEO code while codes 33,41 are Continuous Memory codes
basically im looking for a yes that is correct travis or know your doing it wrong . and possibly help with this. i think i have finally found my problems hopefully.
here is the video(sorry its kinda crappy but i do have music in there for ya haha)
also when i started it up at the end of the KOEO test it blinked 3 times (the revving of the motor is me trying to rev it to 2500RPM's)
