I have a 99 F-150 4x4. Unable to switch from heat to AC. I feel it is a problem with the door under dash as the vaccum lines appear okay. Any ideas?
Thanks,
Gary
If I were you i'd remove the blend door motor and attempt to move the door manualy to see if it's stuck or binding, also plug the motor in and switch temp modes to check the motor operation. PM me your email address I should be able to send you the removal procedure.
