Hey guys, i a question, will heads from a fi. 351 1994, work on a carb. pre smog 351w block? found a cheap set of 94' heads and know someone who needs a set for a 78' bronco. Let me know if they will work. Thanks
That chart doesn't show the older heads but any motor between 1976 and 1984 is considered a smog era motor and all these have heads with oversized combustion chambers to lower compression. So late model heads will actually increase CR on that '78 and improve power and milage as a result.
