GT40 head Exhaust porting ??
F 150Cobra
"Wild HoRsE" Got Torque?
3,642
104
Aruba
since the engine is out on a stand... i have good acces to the exhuast ports.. is thier any benifit of porting the exhaust ports? or are the intakes the ones i need to port?
or can i do some light porting? smoothen out edges and stuff...
FYI... You need the heads off and valves removed to do porting, you don't want metel shavings in your motor.
Every head will benefit from porting, as will most factory intakes, I suggest you search for "porting E7s" on the web, and also check out this website.. http://www.tmossporting.com/tabid/3451/Default.aspx
