- Moderator
- #1
I know some of you don't like to see anything non-Ford related on here, and I apologize to those of you who feel that way. That being said, I've asked this on a few Chevy/GMC forums and nobody seems to know. Big surprise...
My 1987 GMC Suburban. It has a THM 400 transmission, which is basically chevy's C6.
I'm putting TBI (throttle body fuel injection) back on my Subby now that I have the time and money to put into it.
I wanna know if I could put a 4L80E transmission in where the THM400 is.
4L80E as some of you will know, is basically GM's E4OD.
If I take the trans, wiring harness, and ECM from a donor with TBI, and plug it all into mine, I don't see how I could go wrong.
If you had a Gen 8 or 9 Ford with a 351 and C6, and wanted to put an E4OD in it, could you take the E4OD, wiring harness, and ECM out of a donor with a EFI 351 and plug it all into your rig? I think it's the same thing.
Thanks for any input you guys can give. I think I know where I can get a 4L80E for cheap and if I can't come up with any major problems in this plan, I think I'm gonna go for it. I got 3.73s to replace the 4.10s, and with the lock up TC and .75 OD in the 4L80E, i should be able to get 14-15 mpg out of this old beast. as it is, i can usually get 10-11...
Also, advice on putting a 460/E4OD in will also be considered
Thanks!!!
Thanks!!!
