So as I've said time and time again, Thunder has been sitting for some time and has been neglected. The time has come to where I can do something about it, it's time to get her back on the road. I'm not planning on an extreme build, relatively mild...but the results should yield 100rwhp...which will put me at the upper limit of the stock fuel system. The following is the general road map I plan on doing getting there, as time allows:
-.020 or .030 engine rebuild kit
-Heads decked .030/block decked .020 to increase squelch and CR
-Open up intake valves to 2.11
-Cam kit...I have a couple in mind, but want to talk with Comp and Lunati for best fit application and/or custom grind...and for a little advice on springs.
-Double roller timing set
-Port match heads/stock intake for better flow
-Thorley Tri-Y's for better flow
Then if I need a little extra help:
-Adjustable fuel pressure regulator for help at WOT
-Custom Tune to get rid of any deadspots or gremlins
Big assembly will definitely be done by myself. Not sure if I'll have access (or ability) for the machining yet, but I have a couple buddies that might be willing to show me. I'm also not sure if I wanna play with the heads (didn't really enjoy taking apart or putting the broncos back together).
So...any of you guys have any suggestions, don't like what you see or have something I need to know or look out for???
