Fumoto Drain
Or, if you're lucky you can put force against the plug INTO the pan while UNSCREWING it and it usually keep it at bay...I was a pit monkey for a year buddy.....
Yup I use that trick too. But there's always a couple drops that slip by right when you pull the plug so I keep my arm parallel with the truck. No need for a $30 valve.
3,121
67
Michigan
I figured theres alot less of a mess when changing the oil. Also from switching from pan to pan or if i want to put my old oil into empty oil containers then this would be idea. Its only 27 bucks so i figured id give it a shot.
^^I don't have the clearance under my truck, but in a PSD, I'd be tempted to use a piece of tubing to funnel the drain oil straight into the gallon jugs the new oil came in.
'Course, you'd have to save the bottles from the last time you did it, but if you've got the space, seems like the easiest way to collect and store the drain oil.
surewhynot
Rep whores make me sick
13,843
821
Florida
Apples to oranges comparison... Sometimes I need to roll down the passenger window while driving and I physically cannot reach that side of the truck to crank down the window. This is not a case of people physically not able to remove the drain plug-- they just dont want to.
There is no reason you can't pull over to roll down the passenger side window. Unless you just don't want to. :p
flareside_thunder
7,812
246
Mike...you can also burn your excess oil......filter it through a pillowcase and pour it in the tank a little at a time with a mostly full fuel tank.
3,121
67
Michigan
I burn it anyways. Great way to start a fire! (Dont read if your from CA)
JK yeaaaaaaaaaaaaaaaa idk, i just take it to autozone. If i used the old gallons that it came in, and started to accumulate jugs to put the oil into then that would be a better 25 minute trip to autozone down a bumpy road with a open oil container in the box.
This way i can screw the cap back on and take it in and dump it out. Either throw away my old containers or use the new ones i would have empty from the new oil.
Il be changin my oil this weekend so we will see how it works lol
TexasNomad
FTFS Designated DRINKER!
Hmm I wouldn;t mind having one of these for my 79..
I wonder if they made the thread size to match my truck.
3,121
67
Michigan
I got it in the mail today. Cant wait to use it. To bad i gotta wait another 3 thousand untill i can lol
