polarbear
just growing older not up
Is there something I can do to solve the big gap on either side of 2nd??
As far as exhaling, I don't want loud just to help the truck breath...
Yep- back your foot off of the throttle and it'll shift up sooner. The mistake a lot of folks make with an automatic is thinking the transmission will always shift at the right time. What you're experiencing tells me you're flatlining the throttle instead of "encouraging" the transmission to shift a bit sooner. In other words, back off just a bit right when you want it to shift. Mashing the throttle will actually make this condition worse.
Don't forget to use the OD lockout when running in town. Using it also (correct me if I'm wrong) programs a different shift pattern. And yeah, the transmission is computer controlled too, so all a shift kit does is make it slam into gear harder, creating more stress on the components.
This is all pretty funny in a way. Nick complains about the same things in the Marquis, then wonders why the car doesn't do it when I drive it. Answer- he's used to a manual.
