Exhaust manifold
What engine? Do you mean the EGR system?
On the door it should say month and year your truck was made on driverside.
The build date covers the whole truck. Easy way to tell which manifold you have is by looking to see if there is any little tubes running to the manifold. If all you have is the cast iron part that bolts to the head and to the exhaust pipe, then you have the non-air reactor type. There would be 4 small tubes that screw in right by each exhaust port in the manifold by the head if it is the air reactor type.
