I have a 75 ish F250 4x4 with a 77 351M & C6 that I can't seem to explain the revving engine when it's put into drive. At first I thought maybe a loose wire was getting caught on the throttle linkage or something but eliminated that easily enough. It's almost as if the trans is trying to kick down so to speak but I don't much about auto tranny's.
How does the vac hooked to the trans effect it? Could the trans be causing the rev change? Has anyone else experienced this?
New distributor, control module, coil, plugs. Have new cap and rotor as well but not installed yet. I don't think the ignition is the fault as it was doing this before.
![Headbang :headbang: :headbang:](/old/forum/images/smilies/headbang.gif)
