- 64
- 5
Vehicle in question is a 93 F150 5.0L V8, 2wd E4OD. Under acceleration it will ping (more noticeable when engine is warmed up) and will ping when I'm cruising on the interstate and just maintaining the same speed. It's pinging bad enough that I'm really afraid I'm going to put a hole in the piston one of these days and then I'll really be in trouble.
Things I have done/checked so far...
1. Running 89 octane (and trying different gas stations to see if any offer improvement)
2. With the engine idling I'm putting a vacuum on the egr valve and the engine starts to stumble so I'm under the impression the egr system is functioning normally.
3. Can't find any vacuum leaks when spraying a can of carb cleaner.
4. No codes stored at all (both KOEO and KOER)
5. I've run 2 cans of seafoam on 2 separate occasions through the intake trying to clean up any carbon and it didn't make much of a difference.
6. Checked timing twice with the SPOUT unplugged and made sure it was on 10*BTDC.
7. Verified with my scanner that the engine temp is not getting to hot (hovers between 180*F to 195*F depending on driving.)
I'm getting stumped on this and it's really getting me worried. The engine has almost 189K on the clock but if this doesn't stop soon then the clock will be counting no more. If anybody has any ideas let me know.
-Chrono
...Also (off-topic) but when I was typing this all up I cannot see the blinking cursor nor can I jump back up to a previous spot in what I've already typed to make an edit or add anything. Whenever I try it just keeps typing on the end of the last line of text. Is anybody else having this problem?
-Chrono
