EcoBoost exhaust
polarbear
just growing older not up
12,878
607
Boring, Oregon
On the flip side, they spend a fortune to make modern vehicles quiet. I understood that low noise was priority 1.
True, but fuel mileage is an even bigger concern with the new CAFE averages to meet. That, and in a $40K+ truck, noise is a legitimate concern. Not to mention the fact that it's not likely to go to a kid when trade-in time comes around either, and they're the only ones after noise. Skan doesn't exactly fit into the typical buyer's demographic for that truck.
only time a exhaust *SHOULD* void a warranty is if the exhaust caused the part failure.. which on this ecoboost is possible. but most vehicles on the road.. no...
Ford has been extremely aggressive in their intolerance of mods, and they aren't the only ones. GM sidestepped the issue by offering catback exhaust systems through their own parts departments. You mentioned the right word though- "ecoboost." For the (tightly, computer controlled twin turbo) to perform correctly, a certain amount of back pressure has to be maintained.
F 150Cobra
"Wild HoRsE" Got Torque?
3,642
104
Aruba
turbo... backpressure :wasntme: smiliehijacked smiliegitrdone
Turbo Exhaust Theory
http://www.tercelreference.com/terce...st_theory.html
N/A cars: As most of you know, the design of turbo exhaust systems runs counter to exhaust design for n/a vehicles. N/A cars utilize exhaust velocity (not backpressure) in the collector to aid in scavenging other cylinders during the blowdown process. It just so happens that to get the appropriate velocity, you have to squeeze down the diameter of the discharge of the collector (aka the exhaust), which also induces backpressure. The backpressure is an undesirable byproduct of the desire to have a certain degree of exhaust velocity. Go too big, and you lose velocity and its associated beneficial scavenging effect. Too small and the backpressure skyrockets, more than offsetting any gain made by scavenging. There is a happy medium here.
For turbo cars, you throw all that out the window. You want the exhaust velocity to be high upstream of the turbine (i.e. in the header). You'll notice that primaries of turbo headers are smaller diameter than those of an n/a car of two-thirds the horsepower. The idea is to get the exhaust velocity up quickly, to get the turbo spooling as early as possible. Here, getting the boost up early is a much more effective way to torque than playing with tuned primary lengths and scavenging. The scavenging effects are small compared to what you'd get if you just got boost sooner instead. You have a turbo; you want boost. Just don't go so small on the header's primary diameter that you choke off the high end.
Downstream of the turbine (aka the turboback exhaust), you want the least backpressure possible. No ifs, ands, or buts. Stick a Hoover on the tailpipe if you can. The general rule of "larger is better" (to the point of diminishing returns) of turboback exhausts is valid. Here, the idea is to minimize the pressure downstream of the turbine in order to make the most effective use of the pressure that is being generated upstream of the turbine. Remember, a turbine operates via a pressure ratio. For a given turbine inlet pressure, you will get the highest pressure ratio across the turbine when you have the lowest possible discharge pressure. This means the turbine is able to do the most amount of work possible (i.e. drive the compressor and make boost) with the available inlet pressure.
Again, less pressure downstream of the turbine is goodness. This approach minimizes the time-to-boost (maximizes boost response) and will improve engine VE throughout the rev range.
As for 2.5" vs. 3.0", the "best" turboback exhaust depends on the amount of flow, or horsepower. At 250 hp, 2.5" is fine. Going to 3" at this power level won't get you much, if anything, other than a louder exhaust note. 300 hp and you're definitely suboptimal with 2.5". For 400-450 hp, even 3" is on the small side.”
"As for the geometry of the exhaust at the turbine discharge, the most optimal configuration would be a gradual increase in diameter from the turbine's exducer to the desired exhaust diameter-- via a straight conical diffuser of 7-12° included angle (to minimize flow separation and skin friction losses) mounted right at the turbine discharge. Many turbochargers found in diesels have this diffuser section cast right into the turbine housing. A hyperbolic increase in diameter (like a trumpet snorkus) is theoretically ideal but I've never seen one in use (and doubt it would be measurably superior to a straight diffuser). The wastegate flow would be via a completely divorced (separated from the main turbine discharge flow) dumptube. Due the realities of packaging, cost, and emissions compliance this config is rarely possible on street cars. You will, however, see this type of layout on dedicated race vehicles.
A large "bellmouth" config which combines the turbine discharge and wastegate flow (without a divider between the two) is certainly better than the compromised stock routing, but not as effective as the above.
If an integrated exhaust (non-divorced wastegate flow) is required, keep the wastegate flow separate from the main turbine discharge flow for ~12-18" before reintroducing it. This will minimize the impact on turbine efficiency-- the introduction of the wastegate flow disrupts the flow field of the main turbine discharge flow.
Necking the exhaust down to a suboptimal diameter is never a good idea, but if it is necessary, doing it further downstream is better than doing it close to the turbine discharge since it will minimize the exhaust's contribution to backpressure. Better yet: don't neck down the exhaust at all.
Also, the temperature of the exhaust coming out of a cat is higher than the inlet temperature, due to the exothermic oxidation of unburned hydrocarbons in the cat. So the total heat loss (and density increase) of the gases as it travels down the exhaust is not as prominent as it seems.
Another thing to keep in mind is that cylinder scavenging takes place where the flows from separate cylinders merge (i.e. in the collector). There is no such thing as cylinder scavenging downstream of the turbine, and hence, no reason to desire high exhaust velocity here. You will only introduce unwanted backpressure.
Other things you can do (in addition to choosing an appropriate diameter) to minimize exhaust backpressure in a turboback exhaust are: avoid crush-bent tubes (use mandrel bends); avoid tight-radius turns (keep it as straight as possible); avoid step changes in diameter; avoid "cheated" radii (cuts that are non-perpendicular); use a high flow cat; use a straight-thru perforated core muffler... etc.”
"Comparing the two bellmouth designs, I've never seen either one so I can only speculate. But based on your description, and assuming neither of them have a divider wall/tongue between the turbine discharge and wg dump, I'd venture that you'd be hard pressed to measure a difference between the two. The more gradual taper intuitively appears more desirable, but it's likely that it's beyond the point of diminishing returns. Either one sounds like it will improve the wastegate's discharge coefficient over the stock config, which will constitute the single biggest difference. This will allow more control over boost creep. Neither is as optimal as the divorced wastegate flow arrangement, however.
There's more to it, though-- if a larger bellmouth is excessively large right at the turbine discharge (a large step diameter increase), there will be an unrecoverable dump loss that will contribute to backpressure. This is why a gradual increase in diameter, like the conical diffuser mentioned earlier, is desirable at the turbine discharge.
As for primary lengths on turbo headers, it is advantageous to use equal-length primaries to time the arrival of the pulses at the turbine equally and to keep cylinder reversion balanced across all cylinders. This will improve boost response and the engine's VE. Equal-length is often difficult to achieve due to tight packaging, fabrication difficulty, and the desire to have runners of the shortest possible length.”
"Here's a worked example (simplified) of how larger exhausts help turbo cars:
Say you have a turbo operating at a turbine pressure ratio (aka expansion ratio) of 1.8:1. You have a small turboback exhaust that contributes, say, 10 psig backpressure at the turbine discharge at redline. The total backpressure seen by the engine (upstream of the turbine) in this case is:
(14.5 +10)*1.8 = 44.1 psia = 29.6 psig total backpressure
o here, the turbine contributed 19.6 psig of backpressure to the total.
Now you slap on a proper low-backpressure, big turboback exhaust. Same turbo, same boost, etc. You measure 3 psig backpressure at the turbine discharge. In this case the engine sees just 17 psig total backpressure! And the turbine's contribution to the total backpressure is reduced to 14 psig (note: this is 5.6 psig lower than its contribution in the "small turboback" case).
So in the end, the engine saw a reduction in backpressure of 12.6 psig when you swapped turbobacks in this example. This reduction in backpressure is where all the engine's VE gains come from.
This is why larger exhausts make such big gains on nearly all stock turbo cars-- the turbine compounds the downstream backpressure via its expansion ratio. This is also why bigger turbos make more power at a given boost level-- they improve engine VE by operating at lower turbine expansion ratios for a given boost level.
As you can see, the backpressure penalty of running a too-small exhaust (like 2.5" for 350 hp) will vary depending on the match. At a given power level, a smaller turbo will generally be operating at a higher turbine pressure ratio and so will actually make the engine more sensitive to the backpressure downstream of the turbine than a larger turbine/turbo would.
polarbear
12,878
607
Boring, Oregon
All true Jurgen. Right up until three key points.
1. Huge exhaust also means huge turbo-lag Totally unacceptable for a street machine. Ford even went a twin-turbo setup to reduce lag even further.
2. Huge exhaust mit turbo also means the air-fuel mixture needs to be mapped much richer than stock, or the valves will literally melt into their seats.
which brings us to
3. 2011 emissions regulations. Skanks new truck not only has to pass those, but do it for as long as it's registered in the state of Kalifornia. Same would be true in Oregon or Washington, but only in certain areas of the state.
Can't tell the source of the article, but I'm willing to bet it was written by a tuner, not an engineer. High HP at high RPM's, with big turbos mated to small 4-bangers are the markers of drifters, not commuters. I also note that there was no mention of what the suggested mods would do to the engines durability- not a concern of the drifter/street-racing crowd. An RB25DET can put out stoopid HP, but I've also seen some last through one or two stoplights before grenading.
Impressive for 2.5L.
F 150Cobra
3,642
104
Aruba
which brings us to
i saw an RB25Det skyline came from japan and driving it home it Granaded.. they have extremely weak oil pump!!
my friends 280Sx Rd26DeT puts 400Hp letsee how long the engine will last..
Problem is, todays vehicles have so much computer capacity that manufacturers can measure literally everything for tuning strategies. EBP (exhaust backpressure) is figured in on calculations for boost. Change backpressure, (free flowing exhaust), change boost.
So what you're telling me is... More backpressure.... MORE BOOST!!! I'mma go stuff a potato in my exhaust pipe :D
I'm well aware of all of the repercussions involved with doing exhaust. But fact is, if I did it, I would choose my system very carefully and honestly I'd probably just end up swapping the muffler for something else. I have to believe that a well-designed, modest muffler (read: not wide open) wouldn't really affect the back pressure too much.
And again-- I will research the hell out of whatever I do. I hope you guys realize that I'm not stupid...
They take the backpressure reading, the map sensor reading, iat reading, maf reading, and baro reading, then they make calculations from these. When one is showing a reading thats not expected, thats when you see the infamous cel. (this is a generalization, some use more sensors, some less, but you get the idea)
mrxlh
Oilfield Trash
5,904
430
Stigler, OK
I like the sound of the second one.
F 150Cobra
3,642
104
Aruba
so wich one did you choose?
Haven't done anything yet... Still undecided on whether or not I wanna do exhaust. I'm kind of enjoying the silent, relaxing ride.
F 150Cobra
3,642
104
Aruba
i dunno about your truck but try to make the turbo's louder and keep the stock exhuast... after market filter will make them louder :)
I'd be down for that. I like the turbo whine. But what type of filter could I use to make it louder? I definitely don't want an oiled filter.
F 150Cobra
3,642
104
Aruba
maybe the filter they use in the supras and stuff.. chek into them.. they have allot of types of filters for supras/skylines you know those tuners my friend has one on his toyota chaser and it sounds awesome with stock exhuast you can just hear the turbo spool
Truckin4life
Texas Chapter Leader
I know there is a huge debate about k&n filters. But with the factory oiling, they work the best. So with that said, would the potential upgraded power and the sound of the turbo spool be worth a more expensive filter come time to change?
Just a thought. I used k&n filters on a diesel before and you could hear the turbo spool alot better than a typical filter.
Just something to consider.
