Dumb question, Is the engine loose from the transmission?
^^^ Holy crappola dude, that's information we could've used from the beginning. ^^^**could flexplate have been too damaged after the first starter bolts got loose and broke the starter?**
i will look {in the dangged mirror} for {a guy} to {replace the starter-drive, bearings and brushes in}
my old ford starter (still have it but teeth are bit worn) {I can buy a new Standard Motor Products
starter parts from Rockauto.com or Amazon.com} and {match that} with a new flexplate {or maybe
only just replace the ring gear myself?}
Just a thought, could your solenoid be getting locked up and keeping the starter engaged? I've seen this happen before. As well as a faulty ignition switch causing the starter to stay engaged also. I would replace the solenoid since its cheap and wouldn't hurt. If the problem persists, maybe change the ignition switch out.
Sorry, but I couldn`t help but LOL.
If this is not resolved, it will not keep the starter in place. Sounds like the bolt got loose, damaged the threads, damaged the flexplate, and is the main source of the headaches. The longer bolt and nut would work as long as it pulls it tight, and is about the right diameter to keep it from moving outward. If you think about it, it is only those two bolts for the most part that keep that starter in place. If one is loose, or the ear is broken off, it is down to one bolt holding it.the ear which hold starter to trans was in half.
