I think I can do this?
http://www.forddoctorsdts.com/articles/article-06-05.php
If you can find someone with an IDS or a higher end scan tool, they can command the VGT to see if everything is working on that end.Well the unison ring is all clean and working smoothly. However I have little boost. All I can get is about 5 pounds max. it is a little better than before but something is still not correct. I am getting good at R&R with the turbo.
UH VGT ? IDS? Thanks for the help but you may need to dumb it down a little for me.
The map sensor probably repaired it. That is one of the inputs for boost.Running good now. Ford re flashed the computer and installed a new Map sensor, did something with the plug to the glow plug circuit and changed a fuse? Never ran better? I dont get it but who cares.
If you drive one, YOU"LL BUY IT!Thanks for the help on this. it is obvious I needed it. Now to go trade it in on a new 6.7
