ernie, for some of our members, 50% reception time is not good enough.
When I broke down at the track, I called a Tow service I know. I like to know whose towing my baby. When I got the $275 bill from him the next week, I sent it in to AAA for reimbursement and said that I had no service signal in that area and that he happened to be at the track that night too. Four days after sending in the form, I got a check for $275! I consider it a good service.Sad thing is, AAA is getting hard to get use out here, they aren't paying well enough for the tow services to come out anymore, many tow services won't accept it any more. OnStar is nice, when you have signal... but I don't have to pay a monthly fee to carry my own tools and equipment...
Free for the first 12 months... and it works off of a satellite. Barring being upside down, you'll have signal. I do know, for fact, though, that the antenna pointing into the dirt will guarantee no signal.
Were they actual trailer tires, or did you mount truck tires on it?Also, had what seemed to be good tires go to crap on me too. The trailer has ditched what I thought were 3 good tires, had plenty of tread, no cracking, nothing, but all ended up with broken belts. I have one of that group left. Freaking General tires...
Most Cell providers have a TEXT-TO-SPEECH option. You send a text message to a landline phone, it sends a message back to you telling you it's a landline number, and would you like to send it as TTS for like 25 cents... just make sure you leave a complete message of where you are, what you need, and your handicap in receiving return calls. It SHOULD work, so long as you call the Tow company DIRECTLY, and not a switchboard.I do carry a cell phone, but only use it for text messages. I guess I could text my parents and have them call someone.
Yes, they were LT tires, the trick here is that the trailer doesn't get run enough to justify new tires. They were straight tread tires, and the trailer doesn't see many curbs, mostly dirt and gravel when not run on the interstates and other paved roads. To make matters worse, it is triple axle... I doubt I have much over 10,000 on the trailer since I put it together. And just a response, yes, I run at max inflation on my tires, truck and trailer both.Were they actual trailer tires, or did you mount truck tires on it?
Sounds almost like it was doing a bit too much curb jumping, or pivoting. either way, if those manuevers are common, you're better off keeping straight-run trailer tires on it, 10 ply minimum. Keep away from traction tread on a trailer, as they torque harder in turns trying to do their JOB as traction tires. Also, I know this goes without saying, but keep em inflated to the proper pressure... that will bust belts sure as Carl hates being dragged into threads...
I've got AAA, but I refuse to carry a cell phone. I can't afford a vehicle new enough to have Onstar, and I don't like Chevies, but putting that aside, I'd cut the damn thing out the first day I owned the car. Some corporation being able to locate my car any time they damn well please scares the crap outta me.
The Tri-axle's killing em for sure... that's a lot of side-twist in turns; the tighter, the worse lol... On my spread-axle the guy at wingfoot hooked me up with some tires made to take it more; they have a rounded shoulder so they don't fight the turn so much. Or maybe it's the generals after allYes, they were LT tires, the trick here is that the trailer doesn't get run enough to justify new tires. They were straight tread tires, and the trailer doesn't see many curbs, mostly dirt and gravel when not run on the interstates and other paved roads. To make matters worse, it is triple axle... I doubt I have much over 10,000 on the trailer since I put it together. And just a response, yes, I run at max inflation on my tires, truck and trailer both.
