Cant deside wich performance upgrade to get :( help me !
F 150Cobra
"Wild HoRsE" Got Torque?
3,642
104
Aruba
i can afford... a cam and headers.. OR 1.7 rockers and headers.. not both becuase of lift kit and tires..
ROCKERS:
ADVANTEGES: easy to install er
DISADVANTEGES: not so much power... and they are pricey$$$$$ 255$ to be exact
these ones
http://store.summitracing.com/partd...=FMS-M-6564-A50
CAM
ADVANTEGES: very good amount of power...
DISADVANTEGES: hella of allot more work and need more parts... new springs.. and timing chain set... it will be total of about 275$ a little more pricey but for ALLOT more power... and do i need new cam bearings? i dont wanna take the engine out of the engine compartment..
this is the cam
http://store.summitracing.com/partd...255-5&FROM=MG
timing chain:
http://store.summitracing.com/partd...-3230&FROM=MG
springs:
http://store.summitracing.com/partd...42-16&FROM=MG
Lifters:
dont have any idea what lifters should i need? are these good? chek them out
http://store.summitracing.com/partd...16&autoview=sku
msb71
Virginia Chapter Leader
1,624
28
Hampton,VA
The links aren't working , did you have them in your cart when you copied them?Any mod in my opinion is a start , can't wait til I have the cash to start some more mods.
Mike
F 150Cobra
3,642
104
Aruba
sory here are the good ones
ROCKERS:
these ones
http://store.summitracing.com/partdetail.asp?part=CRN-44746-16
CAM
this is the cam
http://store.summitracing.com/partdetail.asp?part=CCA-35-255-5&FROM=MG
timing chain:
http://store.summitracing.com/partdetail.asp?part=CCA-3230&FROM=MG
springs:
http://store.summitracing.com/partdetail.asp?part=CCA-942-16&FROM=MG
Lifters:
http://store.summitracing.com/partdetail.asp?part=CCA-832-16&autoview=sku
If it were me, I'd go with the rockers. I just don't think I would be up to changing the cam and timing chain and stuff.
surewhynot
Rep whores make me sick
13,843
821
Florida
I have put a higher lift cam in an engine with high miles before and had a problem. The valve stems had a bit of carbon build up on them and since they were being opened farther than before, the build up would catch in the valve guides and make them stick open on occasion. The guides eventually wore out.
F 150Cobra
3,642
104
Aruba
not so shure about the miles of the engine.. the truck has 256.xxx miles but my brother said that they rebuild the engine before we bought it 75.000 ago.... im not 100% shure im giong to ask the guy that we bought it from.. and let you guys know..
what do you guys think just go with the rockers for now???
surewhynot
13,843
821
Florida
I don't know. The rockers would increase the lift at the valves. I don't know if the problem that I had is common or not. Maybe somebody else can chime in if they've heard of what I described.
F 150Cobra
3,642
104
Aruba
yeah so i tought.. im giong with
Cam Crane 44232
springs recomended by the cam
headers.
OR !! y can go with both and just lift kit.. and wait the rims and tires for later in the year.. what do you guys think?
d-kuzmen
Master Ford Tech
2,109
79
Connecticut
Cam Crane 44232
headers.
Do the engine mods first. But thats just me.
TheRoadVirus
High-Steppin' Mo-Sheen
Just a thought.. with the cam swap you're going to have to pull the distributor, intake, timing cover, replace lifters as well as timing chain (better safe that sorry, and easier to do while it's tore down) and you won't see the full benefit with the SD injection. Not to mention getting it all set up correctly and all that. I just don't see it being worth the trouble without the MAF conversion.
I'd go with the rockers and headers to start.. don't forget the full exhaust to back it up. Or even just longtubes for now and worry about the cam swap later.
F 150Cobra
3,642
104
Aruba
yeah.... me and my brother talked about it we are giong to get the rockers and headers...
jbish28
former Ford Master Tech
18
Iowa
The thing you have to look at here is if you are going to put a cam in it would be worthwhile to put in new bearings. A lot of parts stores will let you rent a cam bearing install for cheap and its not that hard to do. Just make sure you use assembly lube on the bearings. Do not be afraid to be aggressive with the lube. Just change the oil within 500-100 miles after the swap. However, if you have weak valves or the guides have excessive clearance you are going to have to spend some money at the machine shop. Headers will free up some power, but the cam is a big player. If you are willing to go this, with the time involved, you should pull the heads, and if you are unable, you should take them to a machine shop and have a 3 angle valve job done. That is what I would do, although I would do the valve job myself. Then once you have the cam in with a new valve job and are not satisfied then switch the rockers.
F 150Cobra
3,642
104
Aruba
yeah.. but im thinking of diong the cam job for when i rebuild the engine ... its a 351w with 260.000 miles...
