- 88
- 1
i was driving to a friends this evening and when i went to leave i moved the truck forward and when i went to turn around i pushed the clutch to shift into reverse and the truck went into reverse and when i went and pushed the clutch in to stop the pedal went to the floor and stayed there and the truck kept movin backwards. i had to shut the truck off and put it into neutral and coast into a small parking lot. my friends neighbor came over and said i broke the clutch fork.(i wish ida broke that) when looking under the truck i "bumped" the linkage for the clutch pedal and it moved(i know its not supposed to do that) so i "inspected" the mounting area fro the linkage and saw that the bolt or stud or what ever it is that holds it in place on the bell housing side was sheared completely off even with the bell housing. so my question is what would be the fastest and easiest and cheapest way to repair this? is the peice that broke a bolt that threads into the bell housing or is it a pressed in piece that is fixed to the bell housing? the truck can still be driven but i have to start it in gear and "float" the gears. i can do this easily but at the same time i want to prevent any and all un nesassary damage to my truck and trans. i need my truck to get back and forth to my job as its my only form of transportation right now so i need to have this thing fixed asap. so any and all advice is as always greatly appreciated. also the truck is a 79 3/4 ton 2wd with a werner granny gear 4 speed manual. thanks again in advance,bill
