I found this to be a bit curious...after months of sitting, I noticed the left rear tire on the Bronco started to buldge a bit. I chalked it up to the 40-50* temp drop. Over the next couple of days it loses alot more air. I keep the tires on the Bronco inflated to 42psi, when I aired up the tire it was at 8 psi. I aired up the tire with the expectation of discovering a slow leak. It's been a couple weeks now, and been driving the Bronco that whole time, and no air loss at all. I don't believe anyone wanted to steal my tire air, and I figured if it was a temp correlation it would affect all the tires (but certainly not 34psi). Maybe sitting all that time exposed a weak spot? Anyone have an explanation for this? Like I said, I just found it curious because I've never known for a tire to leak then be ok.
