Good point. So how much is too much on a stock 351W? Anyone know? I've seen plenty of guys over on the other site running at 14*, that's why I assume it's safe...The problem with advancing the base timing on an application like this is that you are also advancing the entire timing table. The only way that I know of to get around that is to use a tuner. So, is 14* base timing in and of itself a problem? As long as you can start the motor...then no. But is there any other spot in the timing table that got advanced far enough to possibly damage the motor? I have no idea. Thats the chance you are taking. All it would take is enough heat in a cylinder (ie. from a load) and enough timing advance in that cylinder to ignite the air and fuel too soon. Then what you have is combustion taking place early enough in the compression stroke to where the power generated by the combustion is actually trying to push the piston back down. Thats bad...
