ABS/Brake line help
Hello I have a 2001 Expedition project truck. It was on fire and I'm replacing the wiring harness and everything else that was melted. The problem I'm running into is the new( from a junk yard) wiring harness had a different ABS module than the original. I was told it would work but I need to re do the brake line ends for the proper sizes, which is no problem but I'm not sure which ports are for front, Rear or master cylinder. Any help is appreciated. Thanks
