5 speed manual wont shift while running. I can put it in gear while its off. Also clutch fluid was low so I added some and now pedal is soft. Checked the slave to see if its engaging the clutch but its only got about a 1/4 inch of movement. So I'm thinking air in the line?
When I was checking the slave I noticed fresh clearish fluid in a very slow drip from the trans fluid pan and bell housing. Could this be brake fluid from the clutch assembly? Or trasn fluid?
