1970Custom
They call me Spuds
Found this on superhighpoutput.com...
shozaam said:Now this car will not start , this is the second time it leaves me stranded. The battery is fully charged, but I don't get any crank. The first time I left it overnight and came back and opened the door with the key ( in case the anti-theft ) was on. It started right away.
Last night it happened again. I don't think is the starter since I don't even hear a click when the pinion engages, I get nothing. I shifted the car to neutral and back to park in case it was the neutral switch was the culprit. That didn't work, I will not try to bump the starter and see if that helps it. Any other suggestions as to where I should check? Again
full battery, no cranking at all, not even a click.
It was the starter. Even the guys at the shop said it was weird that it would not even click.
