- 64
- 5
First of all this isn't mine and I'm going to ask here instead of the other site first. Vehicle is a 92 F150 with a 4.9 I6 4WD.
This truck has been sitting for a year without being started while the owners neighbor tried to "fix" it for a no crank/start issue. We got it towed back to the dealership I work at (I'm the only one who will work on a ford in a chevy dealership go figure. And yes I do own a F150 of my own ) Anyways... the neighbor replaced the starter and solenoid and after I let the battery charge all night it would crank just fine but now no start. I hook my code scanner up and get 542 - Fuel pump circuit open - etc.,.
Now the truck will start and run on carb cleaner which is a good sign especially for sitting over a year. I'm not hearing the pump cycle on when the ignition is first turned on so we know we're not getting fuel for sure. Now I have checked the fuel pump relay and it's clicking on and off like it should. I've tried grounding the blue/orange wire on the eec test plug and cycling the ignition to see if the pump will turn on then and it still won't.
So at this point I'm suspecting a bad pump or the pump is not getting power. What needs to be checked before I drop the tank (thankfully it's only one tank.) My other question is on the code 542 I've read from several sources that the "Fuel pump circuit open" but the second part never agrees i.e. EEC processor to motor ground, inertia switch, etc.,. Does anybody know what the Ford definition for this code is? Thanks.
