- Moderator
- #21
The 4 bbl heads are typically too large for a steet engine that is going to see most of it's life under 6000 rpm.
Nonsense..
Thought you'd like that..
Thanks Duncan...the more I read, that's the conclusion I was coming to...sad panda.
Nonsense..
Thats a good price for a set of heads,
He's been trying to sell the whole motor for $500 for about a year now, so he said it wouldn't be right to take the same or more for the heads than he wanted for the whole engine.
The 4bbl heads will work just not as well as the ones with smaller ports and runners.
Same principle as 'over carbing'...sorta???
Bossman said:I HEAVILY believed in velocity profiling not too long ago. I was suckered into that world hook, line, and sinker.
Ask just about anyone about this, and they bring up 2 engines. The Boss 302, and the Boss 429. Every article ever written on these engines talks about how the huge ports hurt the street manners of these engines. This is where alot of TDL people get their "proof". I wonder what a Boss 429 would do with a CI cam?
Joel5.0 said:.... yup..... the old 302 Boss is always used as the proof. However, one of the things I have been able to learn/confirm/understand here now, was a little event I took part of mooons ago.
We built a little Clevor using a 289, and installed the classic LeMans cam........ saying it was a turd below 4000 RPM was an understatement. Anyway, the owner got pissed and decided to sell the car but keep the camshaft, so we went back and installed the regular 289 stock HFT cam due to a person interested in buying the car. To say that "mismatched" setup pulled like a freight train and revved like a banshee to the moon WAS an understatement..... it even killed a few bugs VW's with 88mm piston kits, cam and Weber's) on street tires in the local clandestine 1/8 track before it got sold....... something it never did before.... . Yet never understood why (just guessed) those huge Cleveland heads (not filled) would work that much better with the stock 289 HFT cam.
To this day, and noticing the actual OEM trend, I wonder what would have happened if would have really engineered the Cleveland heads........ .... perhaps we could be talking about the CLEV-x pushrod heads instead of the LS-x nowadays.
289nate said:Think about this impressive performing very mild 289 Joel has described with Cleveland heads and a garbage stock 289 HFT cam. That absolute junk cam has no real lobe area or lift to take advantage of those heads. Yet, the joke of a cam cleaned up / picked up the lowend significantly while still pulling pretty well up top due to the heads. Sounds like a crude and very limited version of today's trend in everything from truck to sports car factory engines.
This is what I see. Fast forward to today. Take a modern valve train that can reliably use a modern lobe that has plenty of lobe area and lift without having to let the seat and .050 duration get out of hand. Previously necessary duration on the seat and low lift has been taken away more duration is added at higher lifts where the cylinder head is really capable of moving some air. Now the lobe area is where a good properly sized (too big by old school standards) high flowing head can make best use of it over a very broad rpm range. In other words you're now moving a ton of air without letting the bottom end become a mess because of excessive seat duration.
Guys think for a second about what is keeping air speed up in these seemingly excessively large cylinder heads these days.
