4 and 6" lift question
23
0
Hey What becomes a pain or needs to be replaced when doing these lifts on a 4" or 6"(will decide what i will do by the amount of replacing>)
I know at 6" Dropped Pitman arm....and Brake lines usually but is there more to fords at 77-79 age that need to be changed when doing a lift??? Other than whats in the kit...
UNRULEE
^LARGE carbon footprint^
At 4"s the only mod that is NEEDED is a steering correction (pitman arm for 1/2 tons, a couple of other ways for the 250/350 trucks), and something to compensate for caster/driveline anges (degreed c-bushings for 1/2 tons and pinion wedges for the 250/350 trucks). I would suggest however that an upgraded set of stainless exteded length brake lines would be a good idea seeing as you'll be putting added stress on 30+ year old rubber brake lines with larger (heavier) tires.
At 6"s you'll need what the 4" needs but the driveshafts might be getting too short. I have 6"s in my '79 F250 and have flexed it fairly hard with the stock driveshafts w/o issue but you may not be as lucky.
What did you do for a lift ? And what size tires you running ?
23
0
I've done a 6" lift on my old Gmc(shh i know :p ) but i just had to do the Brake lines, dropped pitman and everything else "worked" Oh and i dropped my Swaybar. but otherwise...nothing however its steering was seriously hurt by the lift...Radius of turning turned into tank mode...
5.0
FTF'er
Got any pics of the old GMC?
UNRULEE
6" lift and 35" tires.......for now, next set will be in the 37" range or maybe a little larger.
