351 Vs 352 questions
So a 390 wont bolt up to a c6....
What trans did they use behind the 390s and 428s.
The 390 from my dads 63 Tbird (youve seen the photos, i can post them up) is mated to a C4, and should bolt to a C6.
Hmm Thanks allot guys expect Tony i'm mad at you right now and think you should be hit with some thing blunt..
But any ways thanks guys, I think i'll keep hunting for a 351 winne, I've beenn looking for parts for the 352 and I can't hardly find any thing at all..
Doesn't seem that any one makes any stroker kits or even rebuild kits besides I want some thing I can bolt up to a Aod :D
Find and Old C4 bell housing and put it on the AOD... smilieneenar :rofl:
Sorry about the triple post, but I had to... smilietease
Well come on give me a break i'm still learning this stuff.
I didn't know you could do that?
Yes, modern transmissions have connected bell housings. I am not sure about the AOD since its old, but not that old, if you know what I mean. My dad wants to take the bellhousing off of that C4 and adapt it to a modern 6 speed automatic, adapters and such can be made.
A C4 Transmission:
Mine is really obvious though because the tranny is red while the bellhousing is blue. :p
TexasNomad
FTFS Designated DRINKER!
I would take it the said if I want it I can pretty much just haul it off.
But they don't make any good stroker kits or heck even rebuild kits.
d-kuzmen
Master Ford Tech
2,109
79
Connecticut
It's the same block as the 390, you've got some options, you can make it a 360, or a 390, even a stroker motor, send it out to me i'll take it one more won't hurt.
You could probably use a 390 rebuild kit, and 390 stroker stuff. I just wish I knew more... :p
I really like this idea tho. Very, very, original.
TexasNomad
Ya you know I could but I might run in to allot of issue with things fitting and blah blah and really would rather just deal with some thing that I know I won't have any issues with.
I really dont think it would be that big of a deal to tell you the truth, Im sure it mounts in the same as any other FE motor, and you could probably put 390 internals in it. I wish there were more sources on this, but I would love to see a write up if you did it.
surewhynot
Rep whores make me sick
13,843
821
Florida
I have always been a big fan of the FE series engines. I had a 65 Ford with a 352 in it. Later I built a hot 390 for it. I've had several other trucks with 390's and a galaxy with a 410 FE out of a mercury parklane. What a tire burner that was. :D
