mm_0_mm
Kansas Chapter member
39,000 miles
4.6 auto 4x4 super crew. If you turn the overdrive off, everything seem normal. with overdrive on, after the transmission has shifted and torque converter locked, when you try to accellerate, the tach climbs up but the truck doesn't change speed...if you press harder and get the trans to downshift, everything works fine until it shifts into high again...almost seems like the torque converter is having issues.
Fluid is full and looks fine, doesn't smell burnt.
I realize it will be under warranty, just wondering how big of a problem this really is.
