2000 F150 4wd overdrive shift problem
My f150 4wd slips when the trans is shifting into overdrive,it will complete the shift if you let up on the gas. Any ideas
Shift Concerns: 3-4 Shift (Automatic) Possible Component Reference/Action
222 — ELECTRICAL ROUTINE
Powertrain Control System
· Electrical inputs/outputs, vehicle wiring harnesses, PCM, shift solenoids, OSS, transmission control switch (TCS)
· Carry out Self-Test. Refer to the Powertrain Control/Emissions Diagnosis (PC/ED) manual for diagnosis and testing of the Powertrain Control System. Go To Pinpoint Test A or Go To Pinpoint Test E. Repair as required. Clear DTCs, road test and repeat Self-Test.
· Engine driveability concerns
· Refer to Routine 253.
322 — HYDRAULIC/MECHANICAL ROUTINE
Shift Linkage, Digital TR Sensor
· Damaged or incorrectly adjusted
· Inspect and repair as required. Verify transmission shift cable adjustment; refer to Section 307-05. Adjust transmission shift cable as necessary. After repairing transmission shift cable, verify that the digital TR sensor is correctly adjusted. Adjust the digital TR sensor as necessary.
Incorrect Pressures
· Forward clutch pressure, direct clutch pressure, line pressure
· Check line, direct and forward clutch pressures at appropriate taps; refer to Line Pressure Chart for specifications. If pressures are out of specification, check main controls.
Main Controls
· 3-4 shift valve, solenoid pressure regulator valve, OD servo regulator, 3-4 capacity modulator valve, 1-2 and 2-3 shift valves stuck, damaged or assembled incorrectly
· Inspect for damage. Repair as required.
· Bolts not tightened to specifications
· Tighten bolts to specifications.
· SSA or SSB malfunction
· Activate solenoid using scan tool. If solenoid operation cannot be felt when placing hand on solenoid, install a new solenoid. Inspect O-rings for damage. Repair as required.
· Gaskets damaged
· Inspect for damage and install a new gasket.
· OD servo rod and piston cushion spring or seals damaged
· Worn or damaged OD servo anchor pins
· No. 2, No. 4, No. 7 and No. 9 check balls damaged or missing
· Solenoid screen blocked or damaged
· Clean or install a new screen.
Pump
· Porosity/cross leaks, balls missing, damaged or leaking
· Inspect for porosity/leaks, balls missing. Install a new pump as required.
· Gaskets damaged
· Inspect for damage. Install new gaskets as required.
OD Band
· OD band and reverse clutch drum assembly damaged, worn or assembled incorrectly
· Intermediate one-way clutch assembly damaged
Forward Clutch Assembly
· Seals or piston damaged
· Friction elements worn or damaged
· Check ball stuck, damaged or not seating correctly
Input Shaft
· Seals damaged
