Kaajot
Micro Machine Manager
Did you grind down the sides of the cooper lug and omit the 3g connector then?
I used a light bulb in the wire on my tractor to make it turn on off the charge. As long as the engine is running, the light bulb is on, the alternator is charging. I could have used a resistor, but the light bulb was there, and free.Oh you like those eh?? M/Ts for the win baby!
And correct on the green wire. With the normal truck setup it turns on via the key/battery light in the cluster, with the self exciting regulator on the buggy it`s RPM controlled, same way as the so called GM 1 wire units.
Buggy has an on/off switch for the ignition, and a push button for the starter.
I popped the hood the hood on Big Blue to take a pic of his 3G conversion, but the way it`s clocked you couldn`t see anything. Buggy was the best I could do on short notice.
