- 36
- 0
Hey guys I have a 91 f250 4x4 351 windsor efi and I was hauling a trailor with a scissor lift which is not that heavy and I've done many times well everything was going fine running normal then all of a sudden just stops I pulled off the side of the road and when I'd start it it was idling way lower then normal and when I would try to take off in first it would die and doesn't idle on it's own like it's starving for fuel but there's a new sound under the hood on the passenger side almost like a knock but not quiet I was thinking maybe bad gas since I was low and just gassed up or maybe a fuel filter because the throttle response is horrible and if I push it to the floor it dies I was thinken maybe the throttle body was starving for fuel cause that's really where the sound was coming from I checked all hoses and they were all good what do you guys think before I tear into this thing
