- Moderator
- #21
The truck should have had a DS II at least on it factory, the question is whether it still does. The knocking can echo up through the block. If it is a rod, you should be able to kind of feel it in the pan.
I payed $1200 for tax, title and all so I feel like if I can get it up and going then it would be a great deal. The motor made a 6 hour trip with a 32' camper full of furniture and a couple thousand pounds of tools in my gang box. Its funny now but at the time it was a nightmare. We hooked up the camper and pulled it to the apartment to load our personal items in it and the bumper folded under with all the weight. Time to take the hitch off bend it all back in place and weld the bumper to frame, weld the hitch on top of the bumper and then some iron from there to the frame to tie it in. Time to load my tools. Unhook from the camper, drive to the back and load my gang box. The shocks squat low, rehook to the camper and no good. We have to frame riding on the tires. I have to get creative and cut up my bar from my weight set in a couple pieces... weld them from the plate by the u-bolt on the back axle to the frame therefore not leaving any shocks at all. It was quite a trip. lol We were blessed to make it.
Ok fellas. So from here I am going to do a compression check for giggles and report back to ya. Timing chain is around $16... I can handle that. Should I go ahead and knock it out for giggles? After that I drop the oil pan and check the lower end? I am willing just tell me what all I should do. Thanks much!
Oh yea.. where is the numbers to find out what year the engine is?
First oil pan design like this: 1975 Mustang II with a 302. These cars used a different oil filter adapter w/a FL300 oil filter because there wasn't enough room in the engine compartment to use the longer FL1A.You have a motor from a car that required rear sump. The two plugs are both drain plugs. The one in the front is just to drain the lower area under the oil pump, the back is the main drain. The pan was designed to go over a crossmember at the middle of the motor, and since the oil pump is at the front, it has the pan formed around it. This pan style first showed up in about 79 in Mustangs, Crown Vics, Grand Marquis, and Fairmont/Zephers. It is possible you have one of the early variable venturi motors, which were also computer controlled, which require O2 sensors. It doesn't have the be injected to have an O2, just computer controlled. With the swap done like that, it is hard to tell what all was kept and what was changed. If the distributor cap didn't work, it is possible the PO swapped it all the way back to points. Pics will realistically be necessary to help determine what all changes have been made.
