- 98
- 0
I have a 1976 ford Ranger XLT with a 351 frozen motor in it. I need to know if a 1985 351 would match up with the trans bolts and the motor mounts in my truck?
There are 8 bolts on the valve cover and the other 351 is out of A 1989 ford truck i dont know if that makes a difference
Will a 360/390 bolt up to the trans thats in the truck now? And thanks for all your help!
Don makes valid points...originally, your trucks should have had a 360 in it (I'm assuming 4x4). That said a 351M and FE won't have the same bell pattern. The 85 351 is probably of the Windsor flavor, and as Don said, will have the sb pattern, and won't bolt up. Easiest way to determine what you have is by counting the valve cover bolts. a 351M/400 will have 8, the 302/351W will have 6 and a 360/390 will have 5. If your truck is a 2wd or had an engine swap a 429/460 will have 7 bolts.
Read post #13 ONE MORE TIME!But would the the trans that the 351 is on be able to bolt onto a 360?
