No. 1 is front right? Timing marks on balencer? See a large groove but dosent line up. Should be at 8*? Thanks Neil
Thanks for the. Reply. Might have to sand it down a bit. Not seeing anything but the one big knocth in it.
A plain old graphite pencil will show up well under a timing light as well.
You will be fine running at 8 degrees but if memory serves, the factory spec is 6 degrees.
